News Samsung's 57-inch Odyssey Neo G9 DUHD Gaming Monitor U.S. Preorders Open
So, back when I was looking for ultra-wide, for a combination of work + gaming usability, I vaguely remember thinking about the 49-inch 3840x1080 monitors when they were teasing them, then went with 3840x1600, since it didn't see like those 32:9 monitors were going to be released by the time I needed them.
In hindsight, for my work needs, 3440x1440 would've probably been just fine (losing only about 11% of the horizontal resolution that the dual 1920x1080 monitors a the office gave me), and would've required less GPU grunt for gaming purposes.
But this? Yikes! That's a metric butt-ton of pixels, and seems like maybe too unwieldy of a size.
Fun fact: This may be the first monitor I've heard of where DisplayPort 2.1 is required to drive the full refresh rate and resolution, even with Display Stream Compression. DP1.4a can do 4K 240Hz with DSC at a max (I think that's correct, at least), so presumably this monitor would 'only' run at 7680x2160 and 120Hz on Nvidia GPUs.
Don't hate me Samsung but I'll wait for the OLED version 😅 So this one is like dual 32" side by side right? I wonder if someday Samsung will make a 40" equivalent... like a 79 inch! That's my dream endgame, 40 inch is just the perfect size to display 4K at an arm length. I guess.. buy the OLED 57 and upgrade if someday it ever come out?
This falls into the 'if I won the lottery' category. Then I rethink looking at it in front of me and I would forever fear the top middle pixels of the screen failing or tearing apart because of the pressure.
That thought would never leave my mind so even if I had the money I would never get this.
Nice. But, this would require a desk about at least 30% wider (and a lot deeper) than this 47" curved monitor!
But hey, if you can afford this monitor.....
Need to see how bright it, doesn't sound like it should have Neo name.
I had a G9 but switched missing those extra vertical lines of resolution 4K has.
If they make one this size with 1500+nits I'll buy it.
