Question Samung R55 Help...
FGK1536
28
I have a little Question about my Samsung R55(NP-R55CV01/Seg) Laptop.
The conponents:
-Centrino Duo T2300(2 cores @1,66 GHz, only 32-bit capable)
-2 x 512 Mb Ram
-A Geforce Go 7600(the 256 Mb Variant)
1.I want to install Windows 7 Pro, but my Stepmother wants to install Windows 10. Would it run well? I personally think not...
2.On the Samsung Website, I couldn't find Windows 7/10 Drivers. Could I get them elsewhere?
3.The Geforce Go 7600 isn't the newest card, which card could I get without Bottlenecking the GPU (maximum 25%)?
For the Answer: Sorry, I Accidently Posted it before finishing.
Thanks for completing the post.
Where laptops are concerned, if the laptop maker does not have drivers for a particualr OS, you are advised not to install that OS owing to high probabability that key hardware devices won't work as they should or won't work at all.
Finding working drivers from elsewhere is a lottery --- if you don't mind searching for days or weeks that's up to you.
