SanDisk Cruzer 8GB (USB) problem
Kinder 00
some of the times I cannot open this flashdrive. I get a red X. It reads, "San Disk is already open. To view current session, click on the current San Disk Secure Access Window"
It does not appear anything else is opened. I cannot find the open session therefore cannot get to the files.
Where or what does it look like? I would like to correctly close the file so that I could open the entire flashdrive. Thank you
That's an issue with software provided by SanDisk, and you are more likely to find help from them then here. I use a lot of their products, but I avoid secured areas like the plague because most of the software is, sometime, flaky.
Can you just eject the drive and re-insert it in another port? Does a window come up when you insert it, possibly with a password prompt?
Similar threads
