SanDisk Cruzer Blade 16gb not being recongised by computer
sammbrahh
5
I have a 16gb USB and i will not get recognized by my computer every time i plug it in. Then i have to uninstall it and plug it out and plug it in to make it work. But the next time i plug it in it doesn't get recognized again and i have to repeat the process again.
Can someone please help me
This is the nature of PD's, one time it will work another time it won't. As I said earlier the problem is in the OS and not in the PD.
Whenever i type chkdsk f: /f/r in cmd it says "cannot open volume for direct access". F is my USB drive leter
It works perfectly on my windows 8 laptop but not on my windows 7 computer. I have tried reformatting it on the windows 8 laptop but it still does not show up on my computer for some reason.
Then only one way left is to format the WIN 7 OS, to let the PD work. Before formatting you can try to uninstall device(PD) from Device Manager/Universal Serial Bus Controllers/ expand / USB Mass Storage Device / right click / uninstall. Pull out the PD, and put it back, see if it works. But chances are less. And if any how you make it work then follow the command from my previous post to check the PD.
It worked after uninstalling USB Mass Storage Device. I tried chkdsk again and it worked and found no problems. BUT after ejecting the USB and putting it back in, it did not show up on my computer again.
Yep the problem was with the OS, so i upgraded to Windows 8.1 and it works fine. Thanks lonewolf7 😀
