M Milos_10 Respectable Jan 9, 2017 316 0 1,810 May 8, 2017 #1 So ,my motherboard(asus p8 h61 m le) has 4 pin cpu power connector ,will this run i5 2400 ok?(by the way ,psu is EVGA 500b)
Solution Dark Lord of Tech May 8, 2017 Yes PSU IS FINE. Board is compatible. https://www.asus.com/Motherboards/P8H61M_LE/HelpDesk_CPU/
rgd1101 Don't Moderator Nov 7, 2011 74,864 4,245 176,290 May 8, 2017 #2 What the model of the motherboard? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 May 8, 2017 #3 WHAT board? Upvote 0 Downvote
B boosted1g Titan Jun 12, 2013 14,847 9 81,765 May 8, 2017 #4 Would need to know what motherboard you are refering to before of of us could possibly tell you if it will run an i5 2400. Upvote 0 Downvote
madmatt30 Titan Ambassador Jan 1, 2013 24,571 647 91,240 May 8, 2017 #6 Absolutely fine. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 May 8, 2017 Solution #7 Yes PSU IS FINE. Board is compatible. https://www.asus.com/Motherboards/P8H61M_LE/HelpDesk_CPU/ Upvote 0 Downvote Solution
