Question Sanity check... I can power D5 water pumps with SATA power, right?
fcar1999ta
182
Pretty simple... I am pretty sure I can, but I figured I would come on here to confirm. I am building an external radiator cooling loop, which will require multiple water pumps. My mobo has one pump header, which does not have enough power for more than one pump. So, I am planning to use a PWM splitter to control the pumps, and SATA power to power them. This will work, right?
I assumed that they ran off of the header since the header can support 36W.
While the 4-pin PWM pump header can support 36W, the product image shows the fan header having only 2 wires: RPM feedback and PWM signal. No wires for +12V and ground for powering it.
Direct link if image doesn't load: https://www.ekwb.com/shop/media/cat...dca9de82fb58b1/d/5/d5_g3_pwm_motor_cable.jpeg
Can you tell I haven't opened any of the boxes yet?
So, you jumped the gun? 🤔
