Saphire Radeon 5570 ghosting 2nd monitor.
moabak
52
I have a SAPPHIRE 100293DP Radeon HD 5570 1GB 128-bit DDR3 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Low Profile Ready Video Card w/ Eyefinity. I have two monitors hooked up. The main monitor works fine. But the right hand monitor has ghosting to the right of everything. I keep reading internet forum postings about people returning their cards.
Is this a problem with my card, cable or software settings? I've already sent off for the active adapter to run a third monitor on this card. But if it looks like this forget it.
I am using a VGA to DVI cable connection on that monitor. (I'll try to switch out the cable so it's DVI to DVI in a bit.) The good monitor goes straight VGA from the monitor to VGA on the card. But I keep reading on the net that this is not the source of the problem.
Any help would be greatly appreciated.
