hey guys I recently bought a sapphire 6950 2gb dirt 3 edition with the BIOS switch, and apparently after 2011 ended, they removed the bios switch. Well, a loose screw that they neglected to check if was tight fell out of the graphics card, and broke a fan. I sended it in back to newegg, but they wouldn't replace it. I've considered buying an aftermarket cooler, but it voids warranty. Should i send it back in to sapphire? Would they replace it with a new 6950 without the bios switch, or would they just replace the cooler? Thanks.
