Due to wanting to help BF4 low fps problems I decided to overclock my 7950 a little bit to see if it would help...I set the core speed to 1100 and vram to 1300 on my sapphire dual x hd7950, but in gpu z and MSI afterburner, the speed never goes above the old default 850mhz on the core, or old 1250mhz for the memory. I've seen others have this same problem googling but nobody ever had an answer besides "raise the power limit to +20" but....mine is already set at +20. I set a custom fan profile once the card would reach 70c to set the fans to 100%. Card stayed at about 63-65c using MSI Kombuster.
My problem atm seems to be the GPU refusing to go above 850mhz on the core clock and 1250 on the vram.
here's a link to a topic with others.....maybe it's an inherent flaw to the sapphire 7950? Mine is only two 6 pin connectors....I read only that others came with 8 pin connectors. https://www.sapphireforum.com/showthread.php?31006-Sapphire-7950-vapor-x-boost-problem-and-more/page2&s=8c4aebd5d56087631624c0d3fde0e9c5
On idle my core rests at 501mhz but the vram stays full speed at 1250 constantly. In that topic they said the core should go to 300mhz on idle and the vram to 150mhz.
Seems to have been going on for years now with the sapphire...I wasn't aware of this when I bought it... it also idles at 43-45c which seems high. Gaming, it went to 58c in a multiplayer BF4 match just now.
I've now tried three different programs, CCC, Trixx, and Afterburner. Is it an inherent flaw to the sapphire 7950?
People have talked about updating the bios or modding the bios....seems way over my head honestly, I always heard about that bricking your card.
