Sapphire 7970 OC max OC...
G3ck0_92
33
I can only get my Sapphire Radeon 7970 OC to a clock of 1025, before it crashes. Everyone else seems to be getting much higher than me. Is this just a bad card for overclocking, or am I doing something wrong?
It does have 2 Bios settings, the default one and one clocked at 1100/5000 or something. When I switch to the OC'd one, I get frames that are unplayable, which is odd. Could there be something wrong with my card?
Sounds like either a card issue, but it does also seem like a PSU issue. Tell us your PSU, we've had people saying their PSU is good enough but are really just advertised as 1000W with only like 250W on the 12V rail.
NONONO! Eish you are not raising the cards voltage, you are just raising the max power allowed TO THE CARD.
Use MSI afterburner to increase voltage by 20mV at a time!
Then raising Clock and stresstesting. Raise clock and test until you lose stability.
Raise mV again and continue process until you reach desired OC or unacceptable temps.
Uh, an Antec Earthwatts 650w, or something similar.
Do I really need to though? It's at 950mhz, and I just want to raise it to 1050 or something for now. Surely the default voltage is enough for that? People seem to say that most 7970's can reach 1150 or so without a voltage increase :\
Where did you hear that? Every chip is different. Increase the voltage or leave it below 1050MHz
Stock voltage is 1175. I'll try the second bios again once more tomorrow or something to make sure it isn't working, before I go off and replace it. Overclocking it a bit, letting it run in Unigine for a while, then doing the benchmark for 30 seconds and seeing the frame rate. It is going up, which makes me happy.
Would all Sapphire 7970's be the same voltage?
Also, I've got it up to 1050 now and it's running fine through the Unigine benchmark... though it did crash after about half an hour of Dota 2 at 1025 :\
Okay, so it's going quite well... but it finally crashed, meaning I need more volts, right? Raise by 20 each time? How do I know when to stop raising the volts though? I don't want to put too many in and kill it :\
Before I make the trip, is there any chance it could be my fault? The OC works for a little bit, but then it always freezes my PC. I upped the voltage a bit, but it did nothing. The second bios either has a low framerate, or freezes in games. I'd hate to get another just for the same outcome.
if your 2nd bios crashes then you definately got a bad card. id RMA that asap. i have the exact card running in 2nd bios and it works flawlessy. i left core at 1k mhz but up memory to 1500 and it has passed furmark easily.
Yeah, second BIOS is working. Haven't played for more than maybe 5-10 minutes, so I can't even tell if 1040 is stable.
I have a slow green HDD that has about 1.6TB of data installed on it over the past year, it has slowed down my system. Could this affect the GPU at all? Whether the OC or the frame rate? Tempted to do a reinstall now...
That's what I did, which managed to get it to 1040 :\
Got a little over 10k by switching to BIOS 1. Performance is great now, not as good as others I'm sure, but still great. Though Battlefield 3 seems to have a lower minimum FPS now... I'll out that down to beta drivers.
