HI friends ,
I need a sloution for my graphic card issue. I am bulding a new pc and i have assembled most of the parts. But there is one issue which i need a solution . HELP needed ASAP.
My system components.
Biostar A880GZ
WD cavier blue 500 HD
4 gb corsair 2nos : 8gb
PsU : Corsair CMPSU 430 wats CXV@UK .
Grapihics card : Sapphire ATI Raedon HD5450 2gb DDR 3
Now here is the problem :
I have assembled all the componets togather and then when i added my graphics card and then started the computer i see some random lines accross the moniter and its starts getting pixelated. This happenes only when i connect it to the graphics card but if you remove the vga cable and connect it to the onboard port its runs perfectly without any lines or pixels.
Is there something i have done wrong ( coz i am connecting the vga cable in to the graphics card port. Should i get a DVI connecter and then try to connect it to the graphics card..).
Biostar A880GZ
