S sara831 Reputable Oct 15, 2014 16 0 4,510 Oct 16, 2014 #1 Is the 4gb version of the 270X worth it over the 2 GB? I will just be gaming at 1080p, but I think the extra VRAM means I can use high textures in games like Skyrim right?
Solution S S Suztera Oct 16, 2014 sara831 : These are both only $15 more than the 270X http://www.newegg.com/Product/Product.aspx?Item=N82E16814202099&cm_re=r9_280-_-14-202-099-_-Product http://www.newegg.com/Product/Product.aspx?Item=N82E16814202112&cm_re=r9_280-_-14-202-112-_-Product But is there actually any difference between them? Yes, about 10fps at ultra settings but it gets you near or past 60fps barrier most of the time.If it is $15 extra, consider it. You will want that 3GB VRAM for future games. Here is a review of a HIS R9 280: http://www.guru3d.com/articles_pages/his_radeon_r9_280_iceq_x2_review,1.html
S Suztera Polypheme Mar 18, 2014 12,729 0 60,960 Oct 16, 2014 #2 I would choose the 3GB R9 280 over a R9 270X 4GB. The R9 280 would still be faster than a R9 270X. Overclock it further and you can reach near stock R9 280X Upvote 0 Downvote
S sara831 Reputable Oct 15, 2014 16 0 4,510 Oct 16, 2014 #3 These are both only $15 more than the 270X http://www.newegg.com/Product/Product.aspx?Item=N82E16814202099&cm_re=r9_280-_-14-202-099-_-Product http://www.newegg.com/Product/Product.aspx?Item=N82E16814202112&cm_re=r9_280-_-14-202-112-_-Product But is there actually any difference between them? Upvote 0 Downvote
S Suztera Polypheme Mar 18, 2014 12,729 0 60,960 Oct 16, 2014 Solution #4 sara831 : These are both only $15 more than the 270X http://www.newegg.com/Product/Product.aspx?Item=N82E16814202099&cm_re=r9_280-_-14-202-099-_-Product http://www.newegg.com/Product/Product.aspx?Item=N82E16814202112&cm_re=r9_280-_-14-202-112-_-Product But is there actually any difference between them? Yes, about 10fps at ultra settings but it gets you near or past 60fps barrier most of the time.If it is $15 extra, consider it. You will want that 3GB VRAM for future games. Here is a review of a HIS R9 280: http://www.guru3d.com/articles_pages/his_radeon_r9_280_iceq_x2_review,1.html Upvote 0 Downvote Solution
FAIZ1 Honorable Oct 18, 2013 17 0 10,520 Oct 25, 2014 #5 sara831 : Is the 4gb version of the 270X worth it over the 2 GB? I will just be gaming at 1080p, but I think the extra VRAM means I can use high textures in games like Skyrim right? Extra vRAM doesnt mean high textures .. 2GB is fine untill and unless u are not running multiple monitors Upvote 0 Downvote
