SAPPHIRE HD 6670 1GB GDDR5 DP vs SAPPHIRE Ultimate Radeon HD 6670
hazan
9
Hello Experts,
I am determined to buy one of these card mention in the thread name i.e SAPPHIRE Radeon HD 6670 1 gb ddr5. Both have the same specification but one of them has Hyper Memory Support and the other has no fan and no Hyper Memory Support. I like zero noise of course but I love quality too. what will be the role of hyper memory to give crisp clarity in graphics? is it worth to go for Hyper memory or the silent one?
links:
http://www.sapphiretech.com/presentation/product/?cid=1&gid=3&sgid=1088&pid=1278&psn=&lid=1&leg=0
http://www.sapphiretech.com/presentation/product/?cid=1&gid=3&sgid=1088&pid=1240&psn=&lid=1&leg=0
my system Specs:
AMD Athlon II X2 270 Regor 3.4GHz
Ram 4gb
Windows 8 64 bit
PSU 500W
HyperMemory allows the GPU to access system RAM if there is not enough VRAM on the card. However, graphic cards do not need more than 1GB of VRAM unless you go above 1920x1200 resolution. The Radeon HD 6670 is not a very power card, while you may be able to play some non-demanding recent games at that resolution with medium quality graphics, the performance will not be very high.
In short HyperMemory is useless especially since system RAM is a lot slower than VRAM that is DDR5.
hazan
9
Thank you very much for giving some nice details.Frankly speaking I am great fan of NFS and Dirt series.But I cannot effort very high end graphics card.I have another thought about Radeon HD 7770.Do you know any other card which is near or lower the price range of HD 7770 and better than that?
Sheko Crack
I love the idiots who are all hyped about high end graphic cards like GTX or R9 those idiots are the reasons of why the companies are coming with such expensive cards..to the idiots iam using 6670 1GB DDR5 and iam playing watchdogs on high settings, processor A10 6800K and 6GB ram..not using the godly powered GTX's...morons try other things than what companies tell you about
CrispyChips
531
Maybe if you're running Dual Graphics,since you have an APU,you would not be able to do that on a single 6670 1gb.
The 6670,which is medium/low-end these days.
