If it a single fan it should fit in the case,..thats the biggest problem to solve,..I think that it's only 6.5 inches long,.
Find the card specs and look at the dimensions it is,..and measure the inside of the case where it will go,..also It probably will take up the slot below the PCI-express slot,..so you may have to take that into consideration if it is being currantly used,..
make sure your power supply is enough to handle it too,..
