SAPPHIRE HD RADEON 7870 problem of installing
Keemann
291
Hello, I recently purchased the HD RADEON 7870 2gb of edition from sapphire.
It arrived today, I wired it all up and it powers on but no display.
I then took out the 4 pin out of the primary HDD, the pc boots up but reboots after loading the bios. I then decided to put it back to the way I originally did it, I took out the 4 pin from the optical drive and it booted up but I need the optical drive for the installation disc.
500w psu - not a good brand - source of the problem?
Mobo: gigabyte h61m-s2v-b3
All you need to know, what can I do to solve this?? I have no clue.
Thanks, keemann
(Written on iPhone)
can't say for sure if the PSU is your problem without knowing the full specs of the system but it could very well be; many cheap PSUs don't supply even close to what they claim and could damage other parts of the computer if they end up going out in a spectacular fashion. You can reply with all of your system stats to try and give a more detailed view of the problem, if you know someone with a reliable PSU you can also borrow it and see if switching them out resolves the issue.
It didn't have the 6pin connector, it works now, i brought an OCZ modxstream 600w :)
Thanks anyways,
