Sapphire HD7750 HDMI problem
CharismaticDe
18
My monitor(Benq GW2255) works fine when i connect it through my HD7750 with DVI but when i try to connent it with my hdmi it shows "No connection".Please help i cannot seem figure out the problem whether it is my GPU or my monitor, but my monitor is just a month old and my HDMI cable is brand new ....
Are you trying to use both connections or are you unplugging the DVI first? Check to make sure that the monitor is set to the right input. If you did and it does not work, you need to test the monitor with another HDMI video card and/or yours with another monitor to see where the issue is.
You can also try to contact Benq suppor tor the video card vendor support.
