SAPPHIRE NITRO R9 390 8G case fit?
Yes, that case can fit the NITRO R9 390:
From the case specs above: "Max length space available for PCI slots = 400mm"
SAPPHIRE NITRO R9 390 8G Full Length: 395mm
Going to be tight, but it will JUST fit.
go to pcpartpicker.com it will tell you. along with many other things (it does a compatibly check)
everyone uses this site :) it will tell you if any piece or option you have wont be compatible
Evan
