Sapphire nitro r9 390 package was strange and need help.
Syrus Hussain
142
So i just got my sapphire nitro r9 390 and immediately i noticed a few things off with the box. Theres quite a dent on the corner of the box and there another on the back. I think thats fine because of the foam inside the box but i just saw the sticker seal looked already open. Should i be concerned? Everything looks fine from the view of the little window but theres also saw dust in the sticker as well. I already sent an email to scan.co.uk about this. I asked my friend and he said it should be fine but im not sure. What are some people's experience with scan.co.uk and their returns?
Edit: Mobile typing
Doesn't give you a strong feeling of confidence in the card being unused, does it? I'd probably return it for exchange if they allow that. If they give you a hassle over it, then test the card with a stress test like Furmark to be sure it is OK.
