Sapphire R7 260X OC 2Gb max temps?
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
What is the max temp for the Sapphire R7 260x OC 2Gb edition, because when I'm browsing Reddit and programming my card is at 70-75c and while playing games my card goes up to around 90-100c, Is it normal for this card?
I recently cleaned the cooler and the heatsink from alot of dust, but the card is still performing at 70-75c, no lag ingame or anything.
MSI Afterburner data:
Core clock: 1150Mhz
Memory Clock: 1650Mhz
Power Limit: 0+
Fan speed: 48%
it's not normal........ r7 260x max temp range is 80c.....anything above it, will reduce life span of the card.....maybe the dust still inside of the card,and this is the reason for high temperature
Actually it's the big card I have, this one. Also the case is a Antec VSK4000E.
Currently the case is standing against a wall with the case hole against the wall so it could be that causing the heat?
Note: It's not against the but 5cm from the wall.
I moved the computer and opened the case, the fan is not spinning. And it will only spin if I set to 80% in Trixx.
How can I change that?
I reinstalled the whole os, I'm gonna get the card checked out next week, gonna exchange for my GTX550TI for the time being.
