sapphire r9 270x 2gb power supply 6pin*2?
Reyoch Ch
89
i have zebronics 500w power supply but i t has only 1 6pin coneector the r9 270x 2 6pin..does it work in 1 6pin connector.??
The card cannot work if you don't use both connectors.
You need a new PSU.
XFX TS 550W is a great option.It comes with 1x PCIe 6-pin and 1x PCIe 6+2-pin connector.
BTW,great choice for the graphics card.Sapphire is the best brand for AMD cards,so you made an excellent choice. :)
this will support ??Corsair VS450 ?? does it have 6pin 2?? please reply me
Crossfire means that you have two or more AMD cards.
SLI means that you have two or more nVidia cards.
The VS450 has only 1 6-pin connector.
Get the XFX TS 550W PSU and you will have enough power for your system AND you will have enough PCIe connectors for your Sapphire R9 270X. :)
it still can handle more amps than the XFX just quality isn't as good...no Japanese caps in them etc...it has teapo's which are actually not too bad could be worse...like with CX series capXcon....
Well I tell ya I just got my 600B and yes I was skeptical at first was going to get XFX/seasonic....
its actually pretty strong/good enough for me and everything running so much better after dumping an old underpowered delta 500w unit....
