Hi all,
So I recently bought the Sapphire R9 Fury Tri-x (Air).
After unlocking cores, the shaders are at 3840, and the card seems stable overall, 3D Mark runs without a hitch, and games run smoothly.
However, the few times I've tried overclocking, even a low overclock will cause the whole pc to reset randomly while playing high GPU usage games (like Ark).
Running the game with no overclock is fine.
I was hoping to potentially buy a second R9 Fury in the near future for Crossfire, but if my PSU can't even handle one OC Fury then it'll probably need to be replaced before I can consider that.
The PSU has a 'boost mode' where it adds an extra 100W of power, haven't tried running an overclock with this mode on yet but even if it works, it's a hassle to enable as its a button on the back of the PSU (my case sits on the floor under the desk), and turns off every time the computer is powered down.
So, is my PSU ok to handle R9 Fury crossfire (no OC), or even a single R9 Fury with OC, or should I look at replacing it before anything else?
Specs:
Intel i5-4670 (non-K) 3.5/3.8 Turbo
MSI B85-G43 Gaming Mobo
G.Skill Ripjaws 1600Mhz 16gb (2x8) DDR3
Sapphire R9 Fury Tri-x (Unlocked 3840 Shaders)
Samsung 840 120gb SSD
WD Blue 500gb HDD
NZXT Sentry 3 Fan Controller
Thermaltake Frio Silent 12 CPU Cooler
4x 120mm Blue LED Fans
Blue LED Strip
Corsair Carbide Spec-01 Mid Tower
PSU:
Thermaltake Evo Blue 2.0 850w Gold 80+
Specs:
WD Blue 500gb HDD
Blue LED Strip
PSU:
