Hi!
First my rig:
CPU: Core i5 3570K OC to 4,5 GHz (able to go for 4,9-5 GHz on air, not exceeding 85 degrees - but not needed now)
GPU: GTX 560 Ti DC II @950/2150 MHz
Mobo: MSI Z77-GD55
CPU Cooler: Enermax ETS T40-TA (1 fan config)
Case: CM HAF 912 PLUS (2 fans for now, getting upper 200mm soon)
PSU: Corsair 750W
Screen: 24 inch Iiyama (1920x1080)
Now i feel the urgent need to change my GPU.
I checked lot of tests and what I've noticed is that because I love to play on high AA and AF I'm loosing performance mainly cause of 1 GB 256 bit memory but also my core isn't now as strong as it was before.
I don't consider SLI as an option.
I have three choices which I can afford (Prices in Poland but I will give it in $)
1. New Sapphire Radeon 7870 XT - 300$ + shipment
2. Used Sapphire Radeon 7950 Vapor-X (20 month warranty left ) - 300$ + shipment
3. Used Gigabyte 7950 OC 1 GHz (34 month warranty left) - 302$ + shipment
New 7950 with decent cooler is minimum 370$ and I'm low on budget since I bought my rig month ago.
I'm playing 1920x1080, I like to use AA/AF and I want to be able to run most games on Ultra settings. I'm also a bit affraid of buying used cards because there is OC mania now in POland and lot of people squeeze their cards to maximum so I'm affraid that those used cards may have hidden flaws.
Is it worth it to risk? Considering my config will 7950 give me that much of extra boost?
First my rig:
Mobo: MSI Z77-GD55
PSU: Corsair 750W
Besides - to the person who negrepped, for me it's more useful to see an answer or solution to my problem and not to see negreps on answers without givin the reason.
