Sapphire Radeon HD 6670 1 GB GDDR5 with 20 inch HD Monitor. Will it be a good deal?
grandgalaz
55
My bro has a Sapphire Radeon HD 6670 1 GB GDDR5 graphics card. Will it be a decent performer to play modern games on a 20 inch LCD LED 1600X900 monitor? Would you rather suggest any other size/resolution for the given card? Bring it on..
His system specs
Motherboard-- Biostar mcp6p3
CPU-- AMD Athlon (tm) IIX3 425 Processor 2.70 Ghz
RAM-- 3 GB DDR3
PSU-- 450W
OS- Windows 7 32-bit
(He is going to renovate his system which I asked this for. Therefore, ignore my own system specs.)
A 22" monitor with a resolution of 1920 x 1080 , a decent PSU of 500 to 550W, 4GB of RAM(1600 to 1866MHz) for 32bits OS and 8Gb of RAM for 64bits OS will be fine for modern day games.
And you might consider a more powerful GPU, depending upon your budget.
Thanks for your quick reply and sorry that I didn't reply. He went with Sapphire Radeon HD 6670 1 GB GDDR5 and its performing fine with 20" 1600X900 resolution. Yes you were right :)
