Sapphire Radeon HD7950 Boost Vapor-X vs ASUS GTX 670 DCU II
zece
13
I have a deadline till tomorrow and I'd like a concrete answer. Which one is the better deal, considering either one could be bought at the same price.
trane20
134
well they were direct competitors so u can't say one is better than the other in some games the 7950 will perform better than the 670 and vice versa.
u should go with the one u like so are u an nvidia person or amd ? choice is yours
Welshstig
632
Go with the 670, since the performance is the same but the 670 comes equipped with better drivers and features such as shadow play and g sync and much more.
Also asus is much better than sapphire in my opinion since asus has better cooling, overclocking and looks. Also sapphire uses a plastic shroud 2 here as asus uses a metal one...
So as you can see there is a clear winner.
