Windows 10 64bit
AMD FX 8350
Sabertooth 990FX r2.0
16GB HyperX 1600 RAM
Western Digital 1TB Blue Hard Drive
EVGA 850W 80 plus gold rated PSU
Hey guys. I recently purchased a Sapphire Radeon Nitro+ RX 580 8GB GDDR5 card from newegg. It arrived 2 days ago and I installed it into my system to what appears to be a dead on arrival situation. I'm not sure though because on the outside the card appears to be working. The sapphire LED emblem on the face of the card lights up bright blue and the fans run correctly. Despite this when I turn windows on the card fails to be read by device manager and a basic windows display adapter takes over the video for my system.
I thought I should download the AMD drivers to fix this situation, however when I did this windows crashed and gave me this error message:
Stop Code: System_Thread_Exception_Not_Handled
What Failed: atikmdag.sys
At this point windows restarts and then falls into a loop of crashing - repairing - rebooting and then crashing again until I reach the emergency start up scenario where I can choose troubleshooting options. At this point I chose to start up in safe mode and remove the drivers with DDU. Before I did that however I checked Device Manager again and found that in safe mode with these drivers installed Device Manager was able to read my card. If I booth back into windows without safe mode though the problem persists.
So I cleaned out all the drivers and reinstalled my old R9 270x so I could hop on here, make an account and ask you gurus what is going on exactly! Any and all help would be appreciated, thank you!
edit: It is also worth mentioning that I previously had Windows 8.1 until I realized that the card isn't compatible with that operating system. So I upgraded to Windows 10.
edit2: Also the PCIE slot registers that there is a card in it through SPECCY. My BIOS doesn't allow for checking of PCIE related specs.
