News Sapphire Rolls Out Tiny PC Chassis With Big Style
This is a customized version of a recently popular SFF / MFF case called the SAMA IM01 (amongst other names that vary based on region). It's typically available on NewEgg in it's base form for around $60, and usually has a mesh side panel instead of tempered glass, though apparently tempered glass is coming. It's a very good case that is essentially an NR200 clone but with the ability to fit MATX motherboards, and a bit more room for GPUs and PSUs.
  1. With a gpu that low, all I can think of is... 🎼 Pump pump pump pump the dust 🎼
  2. PC builds are dead, without main components being available back at msrp, and we're still far from it. Congratulations, miners and scalpers, you've killed several markets.
Put all the crotch flashing japanima figurines next to it that you want. It's ugly inside and out and isn't liquid cooled. Bleh...
It’s basically a SAMA IM01 with a glass side panel. The SAMA IM01 however has the option to mount the GPU sideways, but lacked a clear panel to show it off. The Nitro M01 has the clear panel, but removed the ability to mount the GPU on the side… (「•-•)「 ʷʱʸ?
