Sapphire RX460 2gb OC Temp Range concern
pilotgomez
5
Hello, I am concerned about my GPU, Sapphire RX460 2gb OC. When I am playing GTA V it ranges from 60 to 70 degrees celsius when not air conditioned(Humid weather). Is it okay to be on that range? Because I recently applied new thermal solution. Running idle from 33-35 degrees Celsius? Or Because of my new thermal solution? Thanks!
Totally safe and actually good temps. You can also build a custom fan curve with a software like MSI Afterburner to keep them at the desired level.
