Sapphire RX470 Radeon OC Edition total power consumption with i3 6100
Akash_11
Commendable
Apr 21, 2016
95
CPU: i3-6100
GPU: Sapphire RX470 Radeon OC Edition 4GB
RAM: 4x2 GB DDR4
HDD: 2 TB @ 10000 RPM
SSD: 120 GB
don't want extra fan, CPU Overclock or DVD R/W
could anyone please help me to know what will be max power consumption possible with this spec
i already have 430 W PSU and 360 W output UPS.
P.S
Sapphire mentioned < 225 W
i had used PSU calculator but it always recommend much higher PSU !
thanks
you'll be fine
https://forums.overclockers.co.uk/showpost.php?p=29924714&postcount=3050 (a thread talking about sapphire nitro oc 480 8GB, but the same thing aplies to 470 too, the rest of your pc is very frugal anyways)
Change a few settings and this card can be quiet and fast:
I turned down the core in wattman - setting the highest power state to 1185 mhz and voltage to 1000. Put the memory up to 2200 and left the voltage as is.
Into Hitman Absolution benchmark, everything maxed, 8x msaa and fxaa on, v-sync off. Framerate is down from 69.1 to 67.4 compared to stock settings OC bios, but i can't see any difference. Power at the wall is down from 275w to 214w. Gamed for an hour+ and its awesome. Temps settle in at 75 but no...
thanks
i have CORSAIR CX-M series CX430M
i think 500W safe for who using many accessories, i just want to use minimum possible.
It draws from the board and from the 8 pins connectors, and the Polaris is not a power hungry card but nonetheless it's still needs some. I think your PSU is not enough, under strain.
than i will go with RX 460 GB
you'll be fine
Into Hitman Absolution benchmark, everything maxed, 8x msaa and fxaa on, v-sync off. Framerate is down from 69.1 to 67.4 compared to stock settings OC bios, but i can't see any difference. Power at the wall is down from 275w to 214w. Gamed for an hour+ and its awesome. Temps settle in at 75 but no throttling. The fans spin around 1000rpm and are whisper quiet.
also there is a big jump in performance between 460 and 470, but the difference between 470 and 480 is quite minor one (15-20%)
