sapphire toxic r9 280x problem
soccer448
5
I have a
i7 3370k
assus V formula
crosier 750w bronze
trident x 2400 mhz 8 gb
After I intalled the drivers for the graphics chard my screen goes black after windows starting up screen My windows doesn't load until i restore to pervious before the installation I am tired of trying to make it work please help me
I don't think your graphics card is defective, it's more than likely a driver error. Use Driver Sweeper to get rid of all AMD drivers, then go get the newest driver from the AMD website. Restoring won't necessarily get rid of all the AMD drivers. Is this a new build? Or was there another graphics card in your system?
I tried it still my screen goes black after windows 7 screen thing please help me figure it out. could the card be damaged do i return it or the card is fine. I can't figure it out
the one that came with the card from cd And i also tired the one from amd still same problem
So I would assume that Windows did start properly until you rebooted after driver installation? Remove the card and see if you can restore to an earlier point before you installed the card, and make sure to uninstall all AMD drivers. If you can then boot Windows properly, reinstall the card, and if Windows boots properly with the card installed, go to this page here, http://support.amd.com/en-us/download and get the latest driver for your 280X, ignore the driver on the disc that came with your card.
what I did when screen goes black i restore it to an earlier point than I tryed installing it again but gives same thing I just restored it also to point out i have my hdmi connected to the card it works until i do drivers setup. And i tryed two different slots same problem. I already tired installing it from amd but still sam problem.
fixed it thanks for your help
