M Mrmostafaxd Reputable Jun 9, 2015 28 0 4,530 Jun 16, 2015 #1 I want to know whats the maximum clock speed I can get from sapphire vapor-x r9 280x tri-x std with boost UEFI. (normal clock speed is 950 mhz and 1000 mhz boost) and thanks
Solution jimmysmitty Jun 16, 2015 http://www.overclockersclub.com/reviews/sapphire_vapor_x_r9_280x_tri_x_oc/4.htm 1160MHz is what they got, doesn't mean you will get that nor that that will be your limit but the best one is the Toxic which got to 1244MHz. But 1150MHz is the norm with 1200MHz being the top end overclocks for the R9 280x.
jimmysmitty Champion Oct 5, 2007 21,595 596 59,140 Jun 16, 2015 Solution #2 http://www.overclockersclub.com/reviews/sapphire_vapor_x_r9_280x_tri_x_oc/4.htm 1160MHz is what they got, doesn't mean you will get that nor that that will be your limit but the best one is the Toxic which got to 1244MHz. But 1150MHz is the norm with 1200MHz being the top end overclocks for the R9 280x. Upvote 0 Downvote Solution
