Hello all
I am muddling alongtrying to build my first PC. I have a question RE the sata cables as I am not sure how to cnnect them. Ok I understand that they only fit in the drives and psu in one orientation.
The EVGA 850w G2 PSU came with
2 x 3 SATA 5 pin cables
1 x 4 SATA 5 pin cables
My question is: Can I connect the drive end of the SATA cable into several drives. e.g. can he 1 x 4 SATA cable be attached to 4 drives? If not does it matter which SATA connector I use on the cable if plugging into only 1 drive. I have a DVD CD player , ssd, and a HDD to connect.
Also does anyone know what 'hot-plug' and 'NCQ' means regarding the SATA mode selection in the BIOS? I wouldnt know if I was hot plugging or not :/
Please help
Many thanks ndeed in advnce,for your valued advce!
Please help
