SATA cable will not *click* with new hard drive
triscint
38
Hello,
I have just purchased a new black edition 2TB western digital hard drive from tiger direct and when I went to install it in my computer the SATA cable will not *click* and stay secured to the hard drive. I know its not the cable because it works fine with two other hard drives I own. Is this a common problem, should I RMA this drive? Thank you
If you need any more information and or pictures please just ask.
Okay I tried pushing up on the clip while pushing but that also did not work. I have now secured the wire to the hard drive using electrical tape. Anyone see any problems with this?
Do you have on the WD drive those holes for the clip.
