G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi Stephan grossklass
before i have a problem of explorer hanging and un-responsive.
I think my problem is solved.
Thank you very much for your help
Please let me know if you have any tips in making windows xp faster.
Chandra
Stephan Grossklass wrote:
> Kevin Haas schrieb:
>>"Stephan Grossklass" <sgrokla-nospam04q2@yahoo.de> wrote in message
>>>One source of tremendous disk thrashing and CPU load when opening
>>>download folders is the zipfldr.dll Windows Explorer uses per default on
>>>XP and later. That's why I remove the respective keys in the registry
>>>pretty quickly after a (re)install. Speeds up things tremendously.
>>Can you please explain in more detail.
> This method looks like it should work:
> http://jorriss.com/dottext/jorriss/archive/2004/12/09/388.aspx
> Stephan
Chandra
> Stephan
