sATA motherboard not running dual IDE
havoc993
12
hi
i have asus p5-kpl SE motherboard ,
i have a sATA HD installed , now i tried to install a IDE HD and dvd drive
but the pc wont recognize either of them , but they work individually fine
i connected the hard disk and the dvd drive (both are IDE ) using the same IDE cable
so in short when both are connected none works and when one is connected it works fine
On the drive label or beside the connections, there should be a diagram showing the jumper positions. This is a block of usually 8 pins next to the IDE connector, that can have little bits of plastic+metal plugged over them to change how the drive acts.
On one drive, pick the diagram called Master, and put the jumpers into that position. On the other, use the diagram for Slave.
