sata power cable question important needed answered
Abdul_6
321
this image cable above u se i have similar connection , if i use same lead to power 2 hdd will this be a prob
one of the white clip is attached to a fan and other end to the hdd and 1 white connector is available on same wire for me to add another sata power cable on , can i attach it and connect to my sata wil it blow it up
or this question here
http://superuser.com/questions/752769/is-there-any-limit-on-how-many-sata-power-connectors-i-can-extend
it should be ok. though in general these types of adapters are not suggested to be used. the power is not the same between them and it is possible you won't get enough from the molex.
but for just hdd's it should easily be able to handle it
