I'm going to be doing a build where aesthetics will be key. So I'm going to use the NZXT H440 and put two samsung 840 evo's at the front in the two 2.5 inch ssd bays. The problem is that the normal sata power cable is chained which means it won't look as good. Can anyone tell me about sata extensions or molex to sata power? I would prefer for the cable to be braided if possible and the power supply is the ax 760. Thanks
