This motherboard has 8 SATA ports - 4 on the Intel 975 chipset and 4 on a Silicon Image 3114 controller. I have individual (non-RAID) hard drives plugged into both controllers. I am running Windows XP Pro SP2. Here are the two issues:
1. Windows will not recognize any hard drives connected to the Silicon Image controller. It WILL recognize my SATA DVD drive (Plextor 755SA). I suspect the problem is the driver - Silicon Image usually provides separate "base" (non-RAID) and RAID drivers but only the RAID driver was provided by Intel. The hard drives are recognized on bootup, so I don't believe it's a hardware issue. Of course the Silicon Image web site does not have a suitable base driver for this configuration, only the add-in card, which Windows won't recognize as a suitable driver.
2. The Intel 975 chipset SATA controller has 3 possible modes set in the Bios - IDE, AHCI, and RAID. I don't need RAID mode but would like to run in AHCI mode since this enables enhanced features. Switching from IDE mode to AHCI mode causes Windows to crash. Indeed the Intel web site says that if you install windows on a SATA drive while in IDE mode and then switch to AHCI mode, Windows will crash. Well ok, I already discoverwed that, but how do I "update" the Windows installation to work in AHCI mode?
