Hello All,
I bought a SATA to USB cable from DX.com SATA to USB cable
I use the usb 2.0 connected to a 5V 2A (10W) adaptor. The usb 3.0 is connected to the computer.
If i plug it in into a 2,5 inch HDD or a SSD it starts up and i can transfer files.
But if i plug it into a 3,5 inch HDD the HDD does nothing. And the drives are not dead.
What i do see is that when i connect the 3,5 inch HDD to the powersource it does pull power from the adaptor. Only it won't start.
I tried with different 3,5 inch HDD but both won't work.
1st: WD - 30EFRX
2nd: Samsung - HD10SJ
1st: WD - 30EFRX
