SATO CL4NX printer won't print out test page.
fallen00000
7
I have been trying to set up this CL4NX printer and am having nothing but issues.
First of al I connected it to the network with an Ethernet corde, but it will not show up on the network when I search for it. The printer tells me that it is connected, but I still cannot find it. I eventually found the drivers online and when installing I was asked which printer model do I want to install. After I chose the correct one the printer showed up under devices finally. However when I try to print a test page Nothing happens. It goes the Que and never prints.
Did you set up/change your computer to use the SATO CL4NX as the default printer? Make sure that you saved or otherwise "OK'd", saved, or applied the change.
As for the test page is that the test page provided by the printer's configuration screens on your computer or some document you are just trying to print as a test? Check which que the test page is sitting in. You may need to delete the job and try again.
