Saving up to build a pc. Need opinions please
ConfusedPotato
Hey guys! I am saving up to build my own PC for the future and need some opinions on this PC build I put together.
https://ca.pcpartpicker.com/list/YxpksJ
I want to ask are there any suggestions that I can improve the build with or are there any cheaper parts I can get with the same performance. Some of the games I play are League of Legends, CSGO, Minecraft and GTA V. I am planning to get some more intensive games later such as wither 3. Please give me some opinions and thank you for your time ;D
+1 for the Power Supply suggestion above.
Build looks pretty well thought out other than that but i would personally recommend spending less on the Case, go for a Corsair 100R or something thereabouts instead and use the saved cash to chuck in an SSD boot drive and upgrade to 16GB RAM, games are already pushing the boundaries of 8GB. Hope this helps :)
Here is a quick build list edit with the above suggestions:
PCPartPicker part list: https://ca.pcpartpicker.com/list/ZzNbD8
Price breakdown by merchant: https://ca.pcpartpicker.com/list/ZzNbD8/by_merchant/
CPU: AMD Ryzen 5 1500X 3.5GHz Quad-Core Processor ($249.98 @ DirectCanada)
Motherboard: MSI B350M GAMING PRO Micro ATX AM4 Motherboard ($104.99 @ Newegg Canada)
Memory: Corsair...
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory ($133.89 @ Amazon Canada)
Storage: Team L7 EVO 120GB 2.5" Solid State Drive ($54.99 @ Newegg Canada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($59.83 @ Vuugo)
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB WINDFORCE OC 6G Video Card ($335.98 @ DirectCanada)
Case: Corsair 100R ATX Mid Tower Case ($48.99 @ NCIX)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($64.98 @ NCIX)
Total: $1053.63
Generated by PCPartPicker 2017-04-16 11:53 EDT-0400
I'm unsure of the quality of that SSD but's it's real cheap and any SSD boot drive is better than none believe me. Squeezed in 16GB RAM but if the cost is too much go back to 8GB, i would consider a 1x8GB instead though because your Motherboard only has 2 RAM slots so you can add another 8GB stick later when you need.
Get this.
Note that if you're buying more than a month away, these will be obsolete in terms of relevance by then, prices change and new stuff comes out.
Motherboard: ASRock AB350M Pro4 Micro ATX AM4 Motherboard ($104.98 @ NCIX)
Memory: Corsair Vengeance LPX 8GB (1 x 8GB) DDR4-2400 Memory ($71.99 @ Newegg Canada)
Storage: Samsung 850 EVO 250GB M.2-2280 Solid State Drive ($114.98 @ DirectCanada)
Video Card: MSI GeForce GTX 1060 6GB 6GB GT OCV1 Video Card ($309.99 @ Newegg Canada)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply ($39.98 @ NCIX)
Total: $1000.72
Generated by PCPartPicker 2017-04-16 12:19 EDT-0400
