Says 8gb ram unknown. (Also a monitor problem)!!
Just tried that. Said no signal detected on the first slot. 2nd slot it turned off and on all the time. It only seem to work when they're in 2 and 4, this is so weird.
so, are these correct?
for
ram stick #1 slot #1 = your PC wont turn on
ram stick #1 slot #2 = your PC can turn on
ram stick #1 slot #3 = your PC wont turn on
ram stick #1 slot #4 = your PC can turn on
and
ram stick #2 slot #1 = your PC wont turn on
ram stick #2 slot #2 = your PC can turn on
ram stick #2 slot #3 = your PC wont turn on
ram stick #2 slot #4 = your PC can turn on
No, it only works then they're in 2 and 4. Like both at the same time.
whats your mobo?
P55M-UD2
Wait, it's actually like this
Stick 1 slot 1 says hdmi no signal detected
Stick 2 slot 1 says hdmi no signal detected
Stick 1 slot 2 keeps turning on and off
Stick 2 slot 2 keeps turning on and off
Stick 1 slot 3 says hdmi no signal detected
Stick 2 slot 3 says hdmi no signal detected
Stick 1 slot 4 works but says 4gb unknown but still shows 4gb in task manager
Stick 2 slot 4 works but says 4gb unknown but still shows 4gb in task manager
well, i guess you'll need to buy new ones (that supported by your mobo)...
