Says i'm Connected to wifi but nothing works except web browser
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Ok so i installed AVG Virus Protetion and AV PC Tune-up and did a virus scan then i unistalled a few things which i have no clue what i installed but i thought they werent anythign internal like safebrowse or somethign like that because t was making popups i also unistalled PureLeads idk what to do.
you need to do a full scan there could left over from it in the registery also us malwarebytes for a scan ,you hav to reload game client for them on steam and battlnet since you are able to connect to the net they nee to be repair .
Disable AVG to start. See if that fixes it. Also, without knowing that you uninstalled its hard to tell what you could have done.
Disable all firewalls (AVG, Windows, Norton and so on), disable all virus scans. Try to see if the program works.
What programs are you trying to access that wont work? What error are you getting?
I also forgot to mention i unistalled AVG AV and TU, restarted pc and still same problem.
I can't Connect to Steam, Battle.net but if i manually open World of Warcraft i can connect i just cant connect to the launcher. Google Chrome works fine no problems connecting to anywebsite.
Ok so PureLead is for Malware bites which i deleted a long time ago and you are saying i have a virus?
Is PureLead the cause of me not able to connect?
Ok ill get back when im done.
Is it PureLeads thats causeing this?
well i installed malwar and did registry clean and deleted a few thigns now its working idk what the problem was but i got it fixed hopefully
Latest posts
