How do I connect front panel audio jacks on a PC case (phones+mic) to a SoundBlaster Live! 5.1? Most new motherboards have a 9-pin audio connector (looks like a USB connector) for a front panel. Of course, SB Live! doesn't have such a connector. My PC case has a standard 9-pin connector as well as separate 7 wires: black, grey, yellow, brown, red, blue and green. The connector's pins are marked as follows (please view in monospaced font):
<PRE>
FP_MIC [x][x] GND
FP_VREF [x][x] +5V
PHONE_R [x][x] NC
NC [x][ ] key
PHONE_L [x][x] NC
</PRE>
My Creative SounBlaster Live! 5.1 Digital (model SB0220) has the following connectors:
SPDIF_IO (5 pins),
CD_SPDIF (2 pins),
AUX_IN (4 pins),
CD_IN (4 pins),
TAD (4 pins)
as well as a white 10-pin connector which is labeled "For Creative's Proprietary use" in the manual.
I'm not an electronics guru so the question is: what to plug where? Looks like I'm not the only one to face a problem like this, so if this is a dead end I want to know it for sure, if there's a hope, let's try to find a solution.
<PRE>
FP_MIC [x][x] GND
FP_VREF [x][x] +5V
PHONE_R [x][x] NC
NC [x][ ] key
PHONE_L [x][x] NC
</PRE>
SPDIF_IO (5 pins),
CD_SPDIF (2 pins),
AUX_IN (4 pins),
CD_IN (4 pins),
TAD (4 pins)
There's NO chance of connecting an analog front audio panel to an SB Live! 5.1 (SB0220) audio card!!!
Thanks to Ralf Einhorn for this final conclusion.
