Question SB PWR light is on PLS HELP
Nov 14, 2019
4
I just add a new ram and then the pc is not booting. I read that you have to reseat ram or reset CMOS battery/even resetting doing the "switching the jumper" method.
Now I reseat my ram and gpu and all that happens when i start the pc is cpu fan, gpu fan, case fan are spinning and ram is glowing but the monitor has no display and the SBPWR led is lit up on the motherboard. PLEASE HELP ME ASAP.
specs:
*I7 4790
*8gb ram (originally) + new 8gb ram
(Both ram has the same speed and timings. Original ram is Avexir Core ddr3 8gb 1600mhz and additional ram is Team Elite Memory.)
*GTX1050TI
*ASUS H81M-K
*Aerocool Rave 500w PSU
Memory manufacturers guarantee memory to operate in the form sold and not in other combinations you decide to create.
Standby power light means power is connected to motherboard. A solid light is normal. Flashing is a power problem.
But i tried to run the ram individually and the original ram does not make my computer run now
