Scan and Repair disk C: loop every start up
anthoNY-CA
I have read quite a few threads on this topic but the solutions given haven't really helped me. I have a Toshiba Satellite that has been upgraded to Windows 10 recently. While doing a defrag and then scan disk from the desktop I was prompted to restart my computer to finalize repairs.
At the Toshiba boot screen it said "scanning drive for errors this may take over an hour" and stayed on that screen for almost 3 days. Then one day I came home only now it said scanning and repairing drive C: 76% done. That screen stayed for another two to three days as well.
A few weeks before I had this problem whenever I would boot up my laptop if I were to touch the touchpad mouse the boot would cancel and go to a blue screen saying that a problem occurred and that the computer will restart itself. Only if I let it boot all the way to the login screen and used the keyboard commands with tab and space for enter to get to the desktop and actually open and a program, would I be able to bypass is blue restart screen
That being said by accidentally touching the touchpad its end it to that blue screen and restarted the computer. I've allowed it another 6 days to do the same too boot screens. I tried fix that I saw of tapping the spacebar multiple times and now I'm stuck on preparing automatic repair Toshiba boot screen.
Is there any way to bypass to get to the desktop or even get into the BIOS screen? I'm going to try booting from USB but the boot order isn't set to check for USB first so I'm not sure what good that will do as I have a Windows 8 iso Burned on a USB. I'm not computer illiterate but I'm also not an expert of the inner workings and have forgot many command prompt commands
Let's begin with the model number for your Toshiba Satellite laptop, please pass it on so we can scope out its compatibility with the new OS. While you get back to us with the info, have you tried performing a system restore? To me it also seems like your mouse/touchpad/keybaord drivers are causing the BSOD and reboot. In order to get into your BIOS screen you can try tapping the F2, F8, F12 or DEL key just as soon as you power up. SPeaking of BIOS, have you made sure that your BIOS is up to date?
You can also go about recreating the bootable USB installer to rule out any corruption that the installer might've had.
