My goal is to build (from ~scratch) a system on which I can run parallelizeable scientific simulations (ie, more cores is better). I will be occasionally using the system for gaming. I would like to familiarize myself with overclocking, and being able to temporarily boost my computer's performance during lengthy simulations would be a bonus. Stability is important, and I do not want to have to tweak voltages on a regular basis.
I have done some research and put together a preliminary parts list on pcpartpicker (end of the post). Explanation is required on a few parts. First, the graphics card is from my current computer - I'm not purchasing a new one yet. The operating system and applications will reside on the hard drive, and I will use Sandisk ReadyCache to accelerate boot times and general application performance. The Extreme II will contain any large data files needed by my simulations. These data files obviously need fast I/O, hence the high-performance SSD.
My Questions:
Approximate Purchase Date: I am going to build a PC from scratch within the next month or so.
Budget Range: $1500-$1700 after rebates and shipping.
Usage from Most to Least Important:
OS Purchase: I already have an operating system, so I do not need to purchase a new one.
Preferred Website: Newegg, Amazon, TD. No real preference among reputable vendors.
Location: Boulder, CO. I will be going to Microcenter to purchase the CPU.
Parts Preferences: Intel CPU
Overclocking: Yes
SLI or Crossfire: It is possible that GPU computation will lend itself nicely to some (definitely not all) of my computations. If so, then I will probably try out SLI or Crossfire.
Additional Comments: I would like to have a quiet PC.
Why are you upgrading? My old computer does not perform computations quickly enough.
http://pcpartpicker.com/user/yavin/saved/3NNP
CPU: Intel Core i7-4930K 3.4GHz 6-Core Processor ($499.99 @ Microcenter)
Motherboard: Asus P9X79 PRO ATX LGA2011 Motherboard ($295.98 @ SuperBiiz)
Memory: G.Skill Ripjaws Z Series 16GB (4 x 4GB) DDR3-1866 Memory ($189.99 @ Newegg)
Storage: Sandisk ReadyCache 32GB 2.5" Solid State Disk ($39.99 @ Best Buy)
Storage: Sandisk Extreme II 240GB 2.5" Solid State Disk ($159.98 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($59.98 @ OutletPC)
Video Card: Biostar Radeon HD 4350 512MB Video Card ($55.00 @ Amazon)
Case: Cooler Master HAF 932 Advanced ATX Full Tower Case ($149.99 @ NCIX US)
Power Supply: SeaSonic 760W 80+ Platinum Certified Fully-Modular ATX Power Supply (Purchased For $99.00)
Optical Drive: Pioneer BDR-209DBK Blu-Ray/DVD/CD Writer ($69.98 @ OutletPC)
Total: $1619.88
(Generated by PCPartPicker 2014-03-02 16:40 EST-0500)
My Questions:
■ Will Sandisk ReadyCache automatically move my swap file to the cache? If I wind up having a 64 GB swap file (which is bigger than the capacity of ReadyCache), will the ReadyCache have problems? My hope is that ReadyCache will leave the swap file alone, and I could put the swap file on the Extreme II.
■ I have looked at many motherboards, and in particular, I am deciding between P9X79 Pro, P9X79-E WS, Rampage IV Extreme and Rampage IV Black Edition. I tentatively selected the P9X79 Pro because I saw people had overclocked it to 5.0 GHz, and I assume that this means (among other things) that the power is very stable. My question is: Assuming the I/O I need is all there, and assuming that I don't really care about the sound hardware, what difference will I see between the motherboards? Will the answer be different if I need to run 2-4 GPUs in parallel? Are there any new motherboards scheduled/rumored to come out in the next few months that might affect this decision?
■ I love the OC panel that comes with the RIVBE. I saw somewhere that it might be sold separately, but I have not found it. Is there any news on this? Are there comparable things that might work for a P9X79 motherboard? In particular, is there something that provides similar functionality to the "normal mode" (ie, displaying progress during POST, displaying voltages, CPU temps and fan speeds, and being able to change between OC profiles quickly)?
■ If I need to run double-precision GPU computations, is there a good source of double-precision benchmarks? What about benchmarks of multiple lower-end ones run in SLI or Crossfire?
■ I am debating making a custom cooling loop, because I think it would be fun. Are there any considerations which might change my decision?
■ Do you have any further comments, concerns or considerations about this build?
■ Parallelizeable simulations
■ Gaming
■ Stable Overclocking
■ Internet browsing (many tabs)
Overclocking: Yes
Total: $1619.88
