screen flashes chequered boxes and buzzing noise from speakers
timtheninj
Commendable
May 27, 2016
My pc flashes coloured chequered boxes on the screen and does a really annoying buzzing sound and freezes.It used to only happen when i was in chrome then it started while playing rocket league and now it happens on startup before i can log into the PC.
I think it is cause of dried thermal paste in the cpu but i am not sure.
I have a gtx 580
ASUS rampage III gene Mobo
3x 2gigs ram and 1 4 gig ram
a 1000 watt psu
and a v8 cpu cooler
I have updated my gpu drivers
your psu is tier 4 on here (http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html) but then its an older pc so without looking at voltages in bios its hard to say if its to blame. The buzzing isn't good though, it makes me think its PSU. maybe take side of case off and see if you can tell where bizz comes from (or is it from your speakers?)
The flashing boxes could be its also your graphics card instead. i have added tags so others may answer.
From what i can see it is a V12XT and the buzzing happened on the windows screen before any sound was played
yeah i thought i said it was coming from the speakers my bad
