Question Screen goes black and i hear a weird sound coming for the cpu cooler
d1versify
789
7
Hello. Today I used a vacuum to clean my PC.
Now sometimes the screen goes black, everything seems to be working, but i hear a strange sound coming out from the cpu cooler... What could it be?
Djoza
Notable
Apr 5, 2020
1,332
197
940
40
i think that happens because the cpu cooler is not mounted correctly,or not working right or something like that.PCs are programes to either cause a black screen or cause a blackscreen+restart because the cpu is overheating.See if your cooler is mounted properly and see if that was the problem.
d1versify
789
7
so does it work now properly?
Is there any strange sound,also i would suggest removing the cpu cooler (including the heatsink) and cleaning it deeply,just make sure that there is nothing there.If you have thermal paste,change it on the cpu
It is working well right now. But it only happened once today and once yesterday. So time will tell.. I will clean it yes. Thank you very much
