Screen goes black, loud fan noise
ZeroRequiem
653
Hello guys!
My r9 290 tri-x stopped working on friday, it simply gives a black screen after 15 minutes of playing. Screen goes black, and there is an insane loud fan noise as if they were spinning on 100%.
I thought this was a GPU problem so I've switched back to my old HD 6850 toxic.
After 30-35 minutes doing nothing on the desktop, the screen went black and there was this loud as hell fan noise too.
What could be the problem?
System specs:
ASRock Z87 extreme4 mobo
i7 4770k @3,5GHZ
Noctua NH-u14s CPU cooler (could this be loud fan?)
2*4GB G.Skill Ares RAM
240GB Samsung 840 EVO SSD
1 TB WD Blue HDD
2 TB WD Green HDD
650 Watt Corsair CS Series Modular 80+ Gold
Zalman Z9+ case
9 days ago i've built this PC installed everything, updated the drivers then it ran without problem till this friday. Then suddenly black screen with the r9 290. So I've switched back to my old HD 6850 and the same thing happened.
Update: Finally I had the chance to test the system with updated BIOS, bad luck though.
I've inserted the 6850, went to BIOS, theres a pretty good Storage browser, it shows the MoBo and which slots are used and which slots are free,
and it showed that my PCI-E slots were empty, but i've just inserted the 6850, I thought I might have messed it up (how can you mess up seating a card?)
So i've reseated the card, went to BIOS again, Storage browser, and the card shown up! I've closed the bios then, the PC restarted and as if a squadron of WW1 planes were flying over my head the loud fan noise came again, this time without black screen, because I had my integrated graphics still plugged in with a VGA cable.
I've tried to find out where the noise came from, it's hard though but I think it came from the bottom part of the PC, so either the GPU or the ?PSU? fan. I've restarted the system, same level of noise and I'm so scared something gonna happen to the PC I've shut it down again.
One more restart, went to the BIOS, Storage browser and the GPU is nowhere to be found. Since 2 of my GPUs cant go dead at the same day I kinda think its a faulty PSU.
