Screen is Split in two in the same monitor and drivers crashing
Stiler
7
befor we start sorry for not good english
So my loptop screen is split in 2 one up and one down and show the same thing and in the right is about 1 inch only balck and cant put the mous ther
I think i now how to fix this but i cant its somthing with the dispaly drivers
when i use the standart VGA one the screen split but when i use a nVIDIA quadro NVS 135m it work fine but then crash and cant recover so my laptop use the VGA one and screen split again and i go to divice menager the nvidia quadri nvs say that : Windows has stopped this device because it has reported problems. (Code 43)
im using a laptop DELL
You can try going to a previous RESTORE POINT.
That may work if it's a software issue. If it's a hardware issue then the laptop would either have to be repaired or replaced.
You can also try booting to an UBUNTU or other Linux Live distro from DVD. Download Ubuntu, burn the ISO to DVD with Imgburn for example, then boot to it. You may need to change your BIOS boot order.
If you have screen issues running Ubuntu still it's a hardware problem.
